I can't recieve incoming calls
  • Updated 2 years ago
I have a lg g3 and my mom has samsung galaxy s 4. We just upgraded to koodo a week ago. From rogers. Kept the same number. We are able to make outgoing calls and texts. We are not able to recieve incoming calls all you get is a busy signal...anyonehave any ideas?? On hold waoting for support... Thank you in advance!
Photo of erica
erica
Posted 2 years ago
Photo of Mitchell Palmater
Mitchell Palmater
  • 12,976 Points 10k badge 2x thumb
Both of you???
It's definitely a number porting issue then.
You will have to wait on hold and ask to speak to the porting department.
must have been something wrong in your account number or pin you gave the rep.
Photo of erica
erica
Ok thanks. It's just weird we recieved incoming calls other days all up until tonight. The rep did everything...hhm ok will stay on hold. Thanks for thr advice!
Photo of Spence
Spence
  • 8,354 Points 5k badge 2x thumb
Have you turned off and restarted your phones since you stopped receiving calls?
If not, then try that.
Photo of erica
erica
It turns out they have increased calls related to this issue. Bell and cogeco landline networks are not able to make calls to cell phones properly right now and that's why you get a busy signal. Got my ticket number and they sent my info to koodo tech support to work out the issue with bell and cogeco which the support team was currently doing. After i hung up with koodo i tried calling from my bell landline to cell phone and it worked. Apparently this may happen from time to time it is a network thing of bell and cogeco has nothing to do with koodo. All we can do is call in and get our ticket number and let them work it out.
Photo of Spence
Spence
Good to know Erica,   Hopefully it is resolved soon.
