I can't activate "international long distance saver' add-on.
  • 2
  • Updated 1 year ago
My bill says I have it but for $0 therefore it is not activated.  I want to activate it but can't - getting an error or try again later message.
Photo of brian wood
brian wood
  • 174 Points 100 badge 2x thumb
Posted 1 year ago
  • 2
Photo of Mayumi
Mayumi, Mobile Master
  • 112,838 Points 100k badge 2x thumb
International long distance saver is $3/mo add on.
Did you go
Self serve > view rate plan > change my monthly add-ons > International long distance add on ($3/mo)?
Photo of Bernard
Bernard, Official Rep
  • 75,644 Points 50k badge 2x thumb
@Brian, you can also add it via the Koodo app from your phone. Download it if you don't have it, it's a great app to have to see your usage and get add-ons.
Photo of brian wood
brian wood
same error message
Photo of brian wood
brian wood
My list of current add-ons including Pay per use int'l l.d.   $0
I select this and submit to remove the add-on and error message appears.
Please try using email rather than private message on facebook or phone 403 xxx-xxxx
Photo of Bernard
Ahhhhh......I see....Brian don't remove the pay per use one, you will need it. Try to add without removing it.
Photo of brian wood
brian wood
adding while existing add on for 0$ is still present results in error message
Photo of Mayumi
"Pay per use int'l l.d :$0" is there to be able to make international calls.
But it's a higher rate than that you have  "International long distance saver : $3/mo add-on.
Example:
To call Japan with Pay-per use - $0.50/min
                      with International long distance saver - $0.05/min
If you remove Pay per use int'l l.d.   $0, then you won't be able to make international calls.
Photo of Bernard
Good talking to you Brian just now! As discussed the add-on should on your account right now.
