I cannot send texts to a 5 digit number help
  • Updated 2 years ago
Htc 8
Photo of Kim Turner
Kim Turner
  • Frustrated
Posted 2 years ago
Photo of Robert
Robert, Mobile Master
  • 106,744 Points 100k badge 2x thumb
Hello Kim.
What is the number you're trying to contact?
Photo of Junhao
Junhao
  • 172 Points 100 badge 2x thumb
Me 2.I am trying to send a message to Royal bank, but failed.
Photo of Robert
  • 106,664 Points 100k badge 2x thumb
Does it give an error message as to why you'Ve failed?
Photo of Junhao
Junhao
No, it just shows "failed" and notification bar shows "the message was not sent".
Photo of Robert
Maybe it's because the bank is closed? If text function is working normally for you, then it should work for the 5 numbers as well.
Another reason it wouldn't work is because you are roaming?
Photo of Junhao
Junhao
Probably you are right, but this short number(722258) belongs to online banking. It wouldn't be restricted by bank opening time, I thought.
Photo of Jonathan I
Jonathan I, Mobile Master
Oh, it's a short code number. Double check to ensure you have the correct one from the bank. You're not on prepaid are you? I think I recall an issue with those a while ago.
Photo of Junhao
Junhao
Yea,I am definitely not on prepaid one. I am pretty sure I got the right number, because I just replied them below the original message.
Photo of Melissa
Melissa, Employee
  • 11,748 Points 10k badge 2x thumb
Hey Junhao! I took a look at RBC's website http://website.rbc.com/SMS/EN and it seems as Koodo is not listed as a compatible carrier
