I bought data for my prepaid phone and it won't work. It did before now it won't. please help.
data problem
Photo of Mackenzie Leigh Bushey Murphy
Posted 3 years ago
Photo of Ahmad
Ahmad
Is your phone a Koodo phone or an unlocked phone? Was it recently factory reset?
koodo phone from walmart and i samsung just fixed it and sent it back to me.
here is the Model Number / Numéro de modèle: SGH-S730HKMKDO if that helps?
Photo of Yannick
Yannick
Hi there, can you check if data is enabled in your phone? Go to System settings ➔ Data usage. Thank you!
I have done that. Turned it on still won't work. That's why I can't figure it out. Very frustrating!
Photo of Yannick
Yannick
Can you check if the APN settings are properly set in your phone http://koo.do/1RfGEQ5? Thank you!
ok i did step #1 but where do i do step #2?
Photo of Anna
Anna
  • 6,126 Points 5k badge 2x thumb
Hey Mackenzie! When you are in the  Access Point Name tab, you should have an option to edit the access point. What model of Samsung phone do you have exactly?
Photo of Mitchell Palmater
Mitchell Palmater
  • 12,996 Points 10k badge 2x thumb
Anna it's a Galaxy Discover !
Photo of Anna
Anna
Thanks Mitchell! Mackenzie, once you click on Access Point Names tab and a new screen opens, you need to click to the bottom left of your screen (button next to the HOME button), which will prompt another tab to open with the options for "New APN" and "Reset to Default". If you click on "New APN" you will be able to enter the settings that Yannick directed you to :)
THANK YOU THANK YOU THANK YOU SO MUCH GUYS!!!!! REALLY APPRECIATE IT. #AWESOMEKOODOCOMMUNITY #KOODOROCKS
