I bought an Samsung S6 almost 2 months ago, and now the right earphone (and the volume control) stopped working.
  • Updated 2 years ago
Sometimes when i straighten out the wire, it works, but the volume control won't.
Other earphones work fine with the phone.
Can I get these earphones replaced?
Photo of Saki Pathmasiri
Saki Pathmasiri
  • 170 Points 100 badge 2x thumb
Posted 2 years ago
Photo of BobTheElectrician
BobTheElectrician
  • 61,556 Points 50k badge 2x thumb
Time to test out the warranty policy. Bring the phone and the offending component back to where you bought it, though its replacement value is probably best researched at a Dollar store, and you will waste more of your time and the store's patience than the component is worth.
IMHO, most of the OEM supplied accessories are not of first quality. I sprang for some $18 ($12 while on sale) for some decent Sony earbuds from Staples, and tossed the old Samsung set that came with the Note 2.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
Upgrade to some Bluetooth headphones and ditch the wires and forget about the ones that came with the phone like Bob said they're just cheap headphones not worth the trouble of warranty. Koodo sells some reasonable Bluetooth headphones called LG TONE PRO's and I highly recommend them for the price and once you get Bluetooth headphones you'll never go back trust me they make life so much easier.
