I bought a Lg g4 out right from telus Will it work. If i switched simcards and decided to go with yeah
Photo of Da
Da
Posted 3 years ago
Photo of Ahmad
Ahmad
Sometimes Telus phones will work on Koodo and visversa but there is no official list really. The only way to find out is to try a Koodo sim card in the phone
Photo of Mathieu
Mathieu, Mobile Master
  • 60,828 Points 50k badge 2x thumb
In most casses the answer is yes, but theres no way to be 100% sure. If you realize it does not work, you can always buy an unlock code online or at one of those mall kiosks that do it. however going through Telus to unlock would be the easiest and hassle-free option for you.
Photo of Jonathan I
Jonathan I, Mobile Master
More than likely it will work and vice versa. I'm with Telus and so far I've used a Koodo S5, HTC M8, M9, and Note 4 with Telus out of the box.
If for some odd reason it doesn't work, unlock suggestions have been provided already. You could even try eBay or cellunlocker.net.
