I am travelling to Mexico and can't find a travel add-on plan.Is there a plan for texts or limited calls if needed. What are my options?
  • 2
  • Updated 4 weeks ago
I am travelling to Mexico and there used to be a travel add-on plan to purchase for a month. I am having trouble finding it this time. Our hotel has WI-FI, but I would like to havem phone available for texts or limited calls if needed. What are my options?  It seems very difficult to get this answered.
Photo of Judi Devlin
Judi Devlin
  • 80 Points 75 badge 2x thumb
Posted 5 months ago
  • 2
Photo of Allan
Allan, Mobile Master
  • 50,210 Points 50k badge 2x thumb
Koodo has recently introduced easy roam. For you in Mexico it would be a $10/day charge. You only get charged when you send a text, make or receive a call or use data. Use nothing, no charge. Once charged, you have access to your plan for 24 hours.
You can read more here:
Photo of Goran
Goran, Mobile Master
  • 83,064 Points 50k badge 2x thumb
You can use Easy Roam for 10 dollars each 24 hours. It makes out at 100 dollars per billing cycle.
Check out here for local prepaid options as well: http://prepaid-data-sim-card.wikia.co...
AT&T Unidas is surprisingly competitive.
Photo of Camilo_A
  • 30,138 Points 20k badge 2x thumb
Hi there!
Koodo has now EASY ROAM, so for Mexico will be 10$/day ONLY if you use your cell phone.
So the way it works, the 10$ will give you access to your Canadian Plan, so you can use your Mins/sms/Data as if you were in Canada.
Get into your Self Serve account and add EASY ROAM! And remember, it only triggers the charge when you use your cell (Receive or Make a phone call, Send SMS or use Data - Incoming SMS does not count since it is something you do not control)
Enjoy your trip!
Photo of Wes Schellenberg
Wes Schellenberg
  • 62 Points
The Easy Roam plan is very expensive! What happened to the international text add on? That worked great and didn't break the bank.
Photo of Goran
  • 81,622 Points 50k badge 2x thumb
It was removed in place of easy Roam. There is a multi month add-on for the US that rains but that's it. If you want to spend a lot less you can get a local prepaid sim card and use that.
Here is info on cost and options: http://prepaid-data-sim-card.wikia.co...
You can use a VoIP App if you still need to call to Canada such as Fongo or Skype.
