I am on the prepaid $15 base plan + booster add-on mins. I will be abroad for 1 yr. I have no Cdn credit card. How to keep this # active?
I am on the prepaid $15 base plan + booster add-on mins. I will be abroad for 1 yr but wish to keep my number, I have no Cdn credit card. How to keep # active?
Photo of Judy
Judy
  • 92 Points 75 badge 2x thumb
  • relaxed
Posted 3 years ago
Photo of Dennis
Dennis, Mobile Master
  • 187,078 Points 100k badge 2x thumb
Have a friend keep it active for you.
OR
Port the number to Speak Out since their minutes keep your line active for 365 days
http://www.speakout7eleven.ca/why-prepaid-phones
Photo of Judy
Judy
So my friend  can top it up every 90 days with a $15 prepaid voucher and the number will remain active until I return?   How do I "port" the number?
Photo of BobTheElectrician
BobTheElectrician
  • 61,576 Points 50k badge 2x thumb
Set yourself some reminders in calendar app to do the renewals manually every 80+ days or so.
BobTheElectrician
If you really don't care about all that fuss and minute/data balances owing, just port your number out to a VoIP service that will accept your US or other credit card. You will then own the number, and can get calls forwarded to whatever provider you will be using while away, and can re-port to whatever you want when you get back.
Photo of Heidi Brejak
Heidi Brejak
  • 80 Points 75 badge 2x thumb
Quick question. If I live in Canada and have the 50 base plan and traveling to states can I text from there?
Photo of Makkahn Mack
Makkahn Mack
  • 1,110 Points 1k badge 2x thumb
Currently NO
Photo of Dennis
Prepaid is only usable in Canada
