I am living in Toronto right now and I will move to Saskatchewan next month permanently, will my plan changes there ?
  • Updated 2 years ago
Photo of Abhishek Patel
Abhishek Patel
  • 156 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Mathieu
Mathieu, Mobile Master
Hi Abhishek,
You will have to change to a Saskatchewan plan but there you can get a 5gb plan for less than 50$!
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 140,132 Points 100k badge 2x thumb
Going from Toronto to SK I don't think you necessarily HAVE to change plans, Ontario plans aren't really region specific. You probably want to though, as there ARE region specific plans in SK that are a much better deal, as Mathieu said.
Abhishek Patel
I have to tell Koodo about my migration in prior ?
If I move to Saskatchewan with my current plan, will they charge me more for that month ?
What should i have to do from not being charged
If you do not change your plan you will continue to be charged the same as you are now. You will need to let koodo know when you move in order to be eligible for the region specific SK plans.
Photo of Goran
Goran, Mobile Master
  • 90,800 Points 50k badge 2x thumb
And you will likely be asked to change you number as well. I know people posted to Saskatchewan in the air force have been told t need to get a new number.
Abhishek Patel
Thank you
