I am having problems accessing self serve. My email and number not being recognized.. Can anyone help?
  • Updated 2 months ago
Photo of Cari ng
Cari ng
Posted 2 months ago
Photo of Goran
Goran, Mobile Master
  • 94,544 Points 50k badge 2x thumb
Have you finished registering your self-serve account?
Photo of Dinh
Dinh, Mobile Master
  • 38,112 Points 20k badge 2x thumb
@Cari: I would suggest you  try to log in into this https://prepaidselfserve.koodomobile.com/ If you forgot the password, you could reset it.
Prepaid doesn't have easyroam. Their options are here: https://www.koodomobile.com/help/long-distance-travel-and-roaming-prepaid
Photo of Mats
Mats
  • 18,006 Points 10k badge 2x thumb
With prepaid you dont use easy roam and cant add it. You need US talk/text boosters.
As for your log in issues try contacting Koodo for help.
Photo of Cari ng
Cari ng
thank you.. i need US talk? if i am in UK?  Can I contact koodo by email?
Photo of Dinh
Dinh, Mobile Master
Cari,
I would reset the password using the portal. https://prepaidselfserve.koodomobile.com/
You could contact them through email but the instruction could be the same, using the portal to reset the password
Photo of Mats
Mats
Koodo prepaid wont work in the UK. Use the link below for Koodo email and phone number information.
https://www.koodomobile.com/contact-us
