I am going away for 10 months. When I come back, will my phone number still be valid and my prepaid SIM?
  • Updated 2 years ago
Photo of Naomi
Naomi
Posted 2 years ago
Photo of Goran
Goran, Mobile Master
  • 90,990 Points 50k badge 2x thumb
No. After 90 days of non payment your line is completely de-activated. If you want to keep your number an pay less than th minimum to keep your account from deactivating (toping it up with 15 every 90 - 1 days I believe) plus no worry about missing it is losing your number, I'd suggest porting over your number to call VoIP service as it's much cheaper and you can actually still use it if you want with data service so people over here can call you and such.
Photo of Naomi
Naomi
What is a VoIP service? And how do I port it to 7-11 speak out?
Photo of Goran
I suggest using Fongo or Textnow to port it over to because then you can still use it with your phone if you ha data services to b in touch with people back in Canada if so desired. There's others that Bobtheelectrician et al will suggest but I cannot recall if they have phone apps you can use and I fel like that would be more useful to just place and receive calls directly without any call forwarding to be done.
Photo of Goran
VoIP is voice over Internet protocol. It uses the Internet to transmit and receive calls and texts. You require a high speed connection (a couple mbps will do) so you need data service or wi-fi to make use of it. The two I mentioned just now, Fongo and Textnow are free to make a receive phone calls while Textnow is also free to text and Fongo charges 2 dollars a month for unlimited texting. You contact the carrier you want to port to, be it 7/11 or VoIP or anyone else to initiate the porting process. Your account gets closed out as part of the porting process.
Photo of Naomi
Naomi
Sry I'm rly bad at these things, how do I port it over? @Goran thx so much
Photo of Alaa
Alaa, Employee
  • 906 Points 500 badge 2x thumb
To port a number, you just need to provide some informations to the company taking your number over (PIN, Phone number and the account number is sometimes necessary).
Please note that your Koodo account needs to remain active and in good standing for the whole duration of the process.
