I activated Roaming Internationally in Canada at $10 per day and was charged $30 instead why?
  • Updated 3 months ago
Why is my bill additional $30, when i only activated by ROAMING INTERNATIONAL travel for 1 day at $10 extra in Canada. After 24 hours it expires, yet I'm charged $30?????
Photo of Marcin Migdal
Marcin Migdal
  • 92 Points 75 badge 2x thumb
Posted 3 months ago
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 143,326 Points 100k badge 2x thumb
Have you signed into self serve and looked at your detailed pdf bill? What does it say?
Photo of Ranjan
Ranjan, Official Rep
  • 31,356 Points 20k badge 2x thumb
Take a look at the detailed call history of your bill, Marcin (page 9 specifically). It shows usage on 3 separate days, while outside of Canada. You can retrieve your bill from your self serve account here, as Timo stated.
Marcin Migdal
Ranjan, thx for replying. I took a look at the breakdown.
it shows Numbers incoming as 9999 for Tuesday and Wednesday which charged me $10 each. Nothing else. Is there a phone number I can speak with someone about this.
223 Mon May 21 03:29 pm   99999 ROAM/VOY 1:00 - - - 10.00
224 Tue May 22 04:07 pm 99999 ROAM/VOY 1:00 - - - 10.00
225 Wed May 23 03:55 pm 800 747-3202 NOT AVAIL MEXICO 1:00 - - - - 0.00
226 Wed May 23 10:55 pm 99999 ROAM/VOY 1:00 - - - 10.00
Photo of Mats
Mats
  • 24,226 Points 20k badge 2x thumb
Dial 1-866-99-KOODO (1-866-995-6636) or "611 from your Koodo phone. Messaging them on Facebook or Twitter also works.
Photo of Dennis
Dennis, Mobile Master
  • 201,000 Points 100k badge 2x thumb
Did you answer the incoming calls?
Photo of David
David, Mobile Master
  • 96,122 Points 50k badge 2x thumb
99999 is a placeholder for the resetting of your Easy Roam. It does not always  indicate a call, but some often other use (data or SMS), and is reported when the partner carrier notifies Koodo, which is not always instantly. Thus your 99999 reference could be a b it later than the event which triggered it.
Photo of BobTheElectrician
BobTheElectrician
  • 69,822 Points 50k badge 2x thumb
Your $10 service expires after 24 hours. But if you make another call or access data after that period, another $10/24 hours kicks in, etc. Rinse and repeat, I'm afraid.
Marcin Migdal
thx for fast reply. Yes I looked at the plan and it says. Easy Roam INTL $30.00 Total used 3 (Day)
I don't see how that's possible. I turned off my data and didn't use it as i had wifi the after the first day. I was away for 5 days, so if i used it for 3 days somehow i should of been charged for 5, cuz i didn't do anything differently.
how do i see how much data i used on the other 2 days?
Photo of Mats
Mats
  • 13,542 Points 10k badge 2x thumb
Ranjan said to check out your call history on page 9 of your pdf bill so it looks like it was for calling and not data. Your bill should also show any data usage if there was any.
Photo of Goran
Goran, Mobile Master
  • 91,612 Points 50k badge 2x thumb
If it's a data leak of some sort and you see like kilobytes of usage you might be able to get those charges reversed. If it's a fair bit of data you might not.
