Hunting for a specific text notification sound
I'm looking for a way to get the same text notification sound i had on my samsung u410 (a flip phone) on my new galaxy phone. It's Tone 1 under single tones. Sounds like three chirps. I've been hunting but can't find it anywhere. Any thoughts.
Photo of Jt Merlot
Jt Merlot
Photo of Marcus Fenix
Marcus Fenix
  • 15,752 Points 10k badge 2x thumb
You probably won't find it. I do recommend Zedge if you're interested in downloading ringtones for free.
Photo of John Burke
John Burke, Mobile Master
Once you find the sound, I'd recommend you use LightFlow.
The way I set LightFlow up is I switch the sounds & vibrations off within all my individual Apps then tell LightFlow to handle them all for me. That way, personally it's easier for me to adjust sounds within 1 single App that handles them all instead of going into each & every individual App to adjust the sounds. Same applies for LED & Vibration.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
There's a large library of ring tones on crackberry.com that I've downloaded a bunch of ring tones from you could check there. You'll probably need a file manager if you don't have one to place into the notification or ring tones sections of the phone after downloading.
