how to turn data on
Moto g
Photo of Susan Salter
Susan Salter
  • 90 Points 75 badge 2x thumb
  • frustrated
Photo of Jonathan I
Jonathan I, Mobile Master
Settings > Data Usage > select the box that says "Enable Mobile data". This screen is also a changeable data chart that can help you trace your data usage and see which apps eat through your data.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,230 Points 100k badge 2x thumb
Johnathan is correct but if you mean that you have a data lock set up at Koodo you'll have to call them to remove the block and turn your data back on
