How to put monthly plan on seasonal hold
I cannot see anywhere in the self serve to put my monthly plan on
seasonal hold???
Photo of Barb Penner
Barb Penner
Photo of Ivan
Ivan, Mobile Master
You can do so via Self Serve. Ignore the red highlight (this was used for something else).
Just remember that if you are on a promotional plan, you will not be able to select it again upon your return (unless that promotion is still ongoing).
