How to move from prepaid to a monthly plan and keep the same number
Hello,
I've a koodo prepaid offer and would like to switch to a monthly plan. But I want to keep the same phone number is it possible ? If yes, how can I do that ? (In a Koodo shop, they didn't have any ideas)
Thanks
Photo of Lambert Giner
Lambert Giner
  • 92 Points 75 badge 2x thumb
Photo of Dennis
Dennis, Mobile Master
  • 195,954 Points 100k badge 2x thumb
They should be able to complete it in store. They would just port the number over to to a monthly plan just like porting from another carrier
Lambert Giner
They said they couldn't do that ...
Photo of Mayumi
Mayumi, Mobile Master
  • 115,026 Points 100k badge 2x thumb
You should be able to do it. First you open a postpaid/ monthly account. You will need to do a credit check. Then transfer your prepaid number. You need to keep your prepaid account active until porting is done.
Photo of Dennis
The store is mistaken. You can try a different one or even make them call customer service to confirm that it can be done
Lambert Giner
Thanks I'll try another Koodo Store tonight
