How to keep bill down while you`re travelling & not using services here
If I am going to be out of the country for a month and want to use my phone. Should I adjust my plan to a cheaper one since I won`t be using all those minutes and just add pay per use international? Thank you.
Photo of Maureen Corcoran
Maureen Corcoran
  • 80 Points 75 badge 2x thumb
Photo of Camilo_A
Camilo_A
  • 31,746 Points 20k badge 2x thumb
Hi there...
You could definitely change your plan if you want to save some money, but keep in mind that if your existing plan is EXPIRED, you will not be able to have it back...
If your phone is unlocked, you could get a local sim card in your destination and will be for sure cheaper, if not, remember that Koodo only has travel packs for USA, for any other country you are subject to pay per use rates...
For more info about travelling, check the following link:
http://help.koodomobile.com/coverage-...
Maureen Corcoran
Thank you Camillo. Good info.
