How to change from Talk and Text to Canada Wide Data Plan after buying a phone secondhand outside of Koodo?
I bought a Galaxy S2 X from a person on Kijiji. I have switched the SIM card over and it seems to be working fine, but in Self Serve, it won't let me upgrade my plan unless I add a phone with it. Should I pay off my Tab, or do I have another option?
Photo of jetouellet
jetouellet
Log into self serve first.
Then click plans and add ons
Then " change my plan"
What phone did you have before?
Photo of jetouellet
jetouellet
I had a Blackberry Curve, but that worked, thank you!
Yeah the reason i asked is because if you have an older BB you should be sure to take the BB version of whatever plan you're going to use on your S2x. These plans are backwards compatiable with Android and iPhones so if your S2x breaks, you don't have to change your plan (which may no longer be available at the time) and you just throw your sim into the BB and you continue.
It's not a big deal for right now. Glad I could help you.
