How much does data cost per gb after the first 50$
I max out my 2gb pretty quick and will probably continue past the 50$ cap. I know the first 5gb is 10$ per gb but does it stay at 10$ per gb after you get the text you have to reply too? Is there is a cap? If I use 15gb over my limit will I get charged 150$?
Photo of Kyler Roberge
Kyler Roberge
Photo of Dennis
Dennis, Mobile Master
  • 196,070 Points 100k badge 2x thumb
Yes it stays at $10/GB even after 5GB.
Photo of Jonathan I
Jonathan I, Mobile Master
Assuming you're on the $60 plan for 2GB, you should consider getting the $75 plan, then. It gives you 4GB to start with the same overage so you save $5 vs the $60 plan.
