How is the $5 per 250mb overage fee on the current Canada-Wide Double Data Plans charged?
  • 2
Looking at the Canada-Wide Data Double 35 (see below). If I go over 300mb is the $5 overage fee applied right away? For example < 300mb = $35, 301mb - 550mb = $40, 551mb - 800mb = $45 etc.
Are there any other fees I should be aware of?
Photo of mistybusiness
mistybusiness
  • 92 Points 75 badge 2x thumb
  • 2
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
For 300mb you'd pay $10, you pay $5 more every time you go over 250mb. So whether it's 251mb or 500mb you pay $10
and yes if you hit 301mb it's an extra $5 on top of the plan price.
mistybusiness
This response confuses me sorry ahaha, I'm not sure what you are getting at.
I meant 300 mb over your data included in your plan but I worded it really bad I'm sorry. Arika is correct so just try to follow her's, it's worded much better.
Photo of Arika
Arika
  • 1,892 Points 1k badge 2x thumb
If you use 301 MB you will be charged the $5 for the extra 250 MB no matter what. Even if you only use 301 MB. You can track your data on your self serve account at koodomobile.com/selfserve or on the Koodo Self Serve App. Also, depending on which phone you use, you can track your usage and even set a DATA LIMIT ( HTC, ACEIIX, SIIX, NEXUS 4, S3, AND S4) this data limit will need to have your billing cycle date entered as well. Make sure you have the proper date entered or else your data tracker will be incorrect.
< 300 MB = $35
301 MB->550 MB = $40
551 MB->800 MB = $45
Photo of Arika
Arika
there shouldn't be any other fees.
Remember Arika that you can edit your original post instead of making another post. To do so just tap on your post and an option will pop up at the top right of your answer to edit or delete.
Photo of Dennis
Dennis, Mobile Master
@Misty, the example you posted in your question is 100% correct
