How does a snowbird reactivate their phone on line?
Was told I could reactivate on line before my return to Canada. Cannot find where to do this.
Photo of Donna Colangelo
Donna Colangelo
  • 260 Points 250 badge 2x thumb
If before you left you changed plans to the seasonal hold, you'll need to log into self serve and change plans again to some other plan. That will reactivate your phone on the plan you choose.
Donna Colangelo
Okay,thanks. I'll give a try.
I should have mentioned it may take 15 minutes and you should restart your phone after you make the change.
Donna Colangelo
I'm not home until April 20 so, by the sound of it, I should do this when I get home and not before hand?
Yup you can do it then.
Donna Colangelo
Okay, great. Thank you!
