How do we use Call Forwarding Variable?
In response to Billy Munro on Facebook:
Could someone please explain the proper format for using "Call Forwarding Variable"? I see the instructions on Koodo's page, but it's giving me grief. Thanks.
Photo of HootSuite App
HootSuite App
  • 1,100 Points 1k badge 2x thumb
Photo of John Burke
John Burke, Mobile Master
Just to be sure, you have it as part of your Plan / Add-ons, correct?
If not, it needs to be otherwise that might be the reason you're having a problem setting it up. I had problems too until I added it to my account.
It use to be included on older Plans but then got removed on newer Plans so you'll need to add it to your account for 3$/month
Photo of Myke
  • 45,100 Points 20k badge 2x thumb
The addon doesn't control whether it works. It only removes the pay per use rate.
