How do I text on my Nexus S? Many thanks in advance>
Photo of Mike Fung
Mike Fung
  • 92 Points 75 badge 2x thumb
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 139,982 Points 100k badge 2x thumb
The same way you would text on any other android phone?
Photo of Mike Fung
Mike Fung
Thanks Timo. But I have never texted before. Honest!
tap on applications icon (block made up of 16 squares)
find the one for messaging, should look like a speech bubble with a smiley face.
tap new message
choose a contact to send a message to or enter a number to send a message to
tap in the box where it says type to compose
type your message
tap send
the message should be sent
wait for a response.
That should be about it. Apologies if some of the instructions don't exactly match what you see, the emulator I have for the nexus s is about 2 os versions behind.
Photo of Mike Fung
Mike Fung
I think I have got it. Thanks for your patience, Timo. You have also indirectly clarified my confusions.
Photo of John Burke
John Burke, Mobile Master
I'm not a big fan of the stock Nexus Messaging App.
I'd recommend Sliding Messaging from the Play Store--> https://play.google.com/store/apps/de...
