how do I text more than 50 characters
I would like to send a text message with more than the standard 50 characters. I have done this by accident and gotten 1000 characters however have no idea how this happened.
Photo of Kelly Kozak
Kelly Kozak
  • 90 Points 75 badge 2x thumb
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,412 Points 100k badge 2x thumb
If using an Android go into your texting app and press the menu button, then choose settings. Look for an option to change to a larger amount of characters some phones have it some don't. Some have to be sent as mms
Kelly Kozak
no I have an old school flip out phone. Just the basics, calling and texting. Thanks for the try. I also have no idea what mms are?
Photo of Zaphod Beeblebrox
Zaphod Beeblebrox
  • 50,808 Points 50k badge 2x thumb
MMS is a function such as picture messaging, sending sound clips, videos through texting.
And some phones send large messages as an mms (picture message)
checkbooks phones settings under text or input or language for a option to expand texting limits
Photo of rikkster
rikkster, Mobile Master
  • 68,316 Points 50k badge 2x thumb
Thought most phones (even old school devices) could send between 140 to 160 characters per text message. If it goes over that number, the message often gets split. I'm wondering if there's a text message stuck in draft mode that's preventing the OP from sending more than a 50 character text message.
What phone model do you have Kelly?
Photo of Ivan
Ivan, Mobile Master
I've never heard of a 50 character SMS limit. The limit is 160 for ASCII and 70 for Unicode.
Photo of rikkster
Neither have I, although I have seen 140 8-bit characters used in older devices.
Kelly Kozak
Thanks everyone problem solved. Yahoo I can send bigger messages now!!!
Photo of Marcus Fenix
Marcus Fenix
  • 15,752 Points 10k badge 2x thumb
I wonder, were you trying to type in the area where the phone number goes?
Photo of Dianne Sorensen
Dianne Sorensen
  • 60 Points
I have only 50 character texting...no choices under the SMS
