How do I send/receive picture ?
I just buy a Samsung Ace and I can't send or receive Picture .. why ? they (koodo) send me a message with the website ''koodomobile.com/bb'' instaed of the picture but this website dosnt work...
what am I suposed to do ?
Photo of Audrey-Anne Lessard AT
Photo of Get it solved !
Get it solved !
  • 4,044 Points 4k badge 2x thumb
Hi Audrey. Your problem could be because you asked to block the internet on the koodo side. Being able to send and receive picture depends on whether the internet is blocked or not .Can you confirm ?
Hmm, I didnt ask anyting like that.. I can go on internet just fine
Get it solved !
Ok i think that it is time to call them and make sure that if any data block that they remove it
yeah I think too...
Get it solved !
Just let me know if calling them fixed it :)
Photo of Ahmad
Ahmad
You don't need to even call. Log into self-serve and if you do have a data block, under add-ons it will be listed. If so, go to "change add-ons" and you can remove it yourself.
Get it solved !
Yeah , if you do have access to self serve it is another way to get it removed. Thanks Ahmad for pointing out that !
