how do i read my incoming text messages
  • Doesn't Need an Answer
I have a lg optimus l3 e400b and cannot find my incomming text messages why?
where do I look for them?
Photo of Louise Sicard
Louise Sicard
Photo of Some random Mobile Master
Some random Mobile Master, Mobile Master
  • 39,554 Points 20k badge 2x thumb
Bonsoir Louise!
Utilisez l'application de Messagerie texte :)
Good evening Louise!
Please use the text messaging app! :)
Louise Sicard
how do not get my text messages where do i find them first?
The picture I posted shows you what app you need to use to read/send your SMS (short for text messages). The app itself is very straightforward. You simply need to tap its icon to open it up and from there, there's gonna be a list of all your messages. You simply tap on any of them to read it.
To send a new text message to someone from scratch, you open the same app, and in the menu bar you click the "+" icon. All you need is your recipient's phone number, which you enter in the bar at the top. Then you type your text, then "Send" (sometimes it's a right-pointing arrow icon) and you're done! :)
Vous pouvez aussi continuer en français si vous êtes plus à l'aise :)
