how do I check how much data I've used not showing me
It's not saying that I used date
Photo of Tammy Michael
Tammy Michael
  • 90 Points 75 badge 2x thumb
Photo of Daniel Kim
Daniel Kim, Mobile Master
Here is another way to monitor usage or apps such as 3g watchdog http://blog.laptopmag.com/how-to-moni...
If you're talking about self serve not showing you how much data you've used, it can take a while to update.
Tammy Michael
I have koodo selfserve
Photo of Dennis
Dennis, Mobile Master
  • 196,866 Points 100k badge 2x thumb
When was the data usage last updated? It usually has a 24 hour delay
Tammy Michael
I just use it to day
Photo of Dennis
Check again tomorrow. It should be there. If not, give Koodo a call to make sure your data usage is noted. Just because it does not show in your usage does not mean you are off the hook... just FYI.
If you do want live data tracking, Android should be able to track it as well. Or you can go the app path mentioned by Daniel above
