How do I block incoming calls ? I see Block MMS what is MMS
I want to block a number..I have a phone number someone had before and these people won't stop. I tell them but we all know how that goes..
Photo of Elenor Babine
Elenor Babine
  • 160 Points 100 badge 2x thumb
Photo of Ahmad
Ahmad
The only way to block a number is through your phones settings, IF your phone supports it. Or through an app through your operating systems' app store. What kind of phone do you have?
Blocking MMS means blocking picture messages, video messages, voice notes, etc from being received by you from others
Elenor Babine
I have a Nokia Lumia 610 . And Thank You for answering so fast.
Photo of Yannick
Yannick
Hi Elenor, I checked the Lumia 610 and it doesn't have the option in the Settings to block a number. It also seems that there are no apps at the moment that can block numbers on Windows phones (such as yours). This website found a work-around but we can't guarantee that it will work: http://koo.do/14fYhVv. Hope it helps!
________________________
Photo of Marcus Fenix
Marcus Fenix
  • 15,752 Points 10k badge 2x thumb
If it gets bad, you can try to report the number or do a phone number change.
Photo of John Burke
John Burke, Mobile Master
WP7 doesn't support it but you can put a vote here for that feature--> http://windowsphone.uservoice.com/for...
