how to upgrade data without losing the voice plan
I want to upgrade my plan to have more data but I dont want to lose anything with my voice plan
I have the unlimited long distance across canada and i just want to add more data - how do I do this and which plan can I choose
Photo of Terri Rich
Terri Rich
  • confused
Posted 3 years ago
The plans aren't piecemeal, you'll have to either use more data and pay the per use charge of your plan, or take a whole new plan. Paying the overage may actually be cheapest
For instance the overage rates of some grandfathered plans may be 10$ per GB while today's plans may be 5$ per 250mb.
Make sure you check out your plan in self serve before you switch.
Photo of Terri Rich
Terri Rich
Im willing to go to the next plan but I am not sure how to do that? and will i lose my voice plan that I have by choosing a new voice plan.
My plan doesnt say much about what I have ? or im unable to find that info
You may or may not be happy with your overage rate as I stated above. .
Log into self serve and check your plan description for the rate... If you don't see it you'll need to call in and ask
Photo of Terri Rich
Terri Rich
but my plan has unlimited long distance across canada - anytime do the other plans offer that as well?
Yes,
Here is where you can shop for plans.
Make sure to select the region you live in at the top
https://www.koodomobile.com/rate-plans
Here is an example of Ontario plans.
Photo of Terri Rich
Terri Rich
is it possible to call in and talk to a rep about this change?
Photo of Dennis
Dennis, Mobile Master
  • 186,618 Points 100k badge 2x thumb
Yes but it will cost money if your ask them to complete a change that you could have done yourself on self serve.
https://www.koodomobile.com/contact-us
If you currently have an outstanding tab, you will have to pay that off too
