How to set up international roaming add-on from UK?
  • Updated 12 months ago
Hi, I want to set up the "ALL40" add-on in the UK. I didn't set it up before I left Canada, and now I'm unable to send any text messages...but online it says to text "ALL40" in order to activate the plan! Is there another way to activate?
I have an LG G4 and I have enabled both international voice and data roaming.
Thanks!
Photo of Kristen
Kristen
  • 106 Points 100 badge 2x thumb
Posted 12 months ago
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,756 Points 100k badge 2x thumb
Hi Kristen, here's a link to a previous question asking exactly this that should help. Enjoy your trip and have a great day. https://community.koodomobile.com/koo...
Photo of Kristen
Kristen
Hi Paul- thanks, I saw that question, but I don't see any way of adding the package online. Self-Serve still requires a text activation (as the other poster also pointed out).
Photo of Kristen
Kristen
Worth a try, but no. They've substantially changed their website since those screenshots were taken. I think I've looked through the website pretty thoroughly, but I'll keep trying. Might call Koodo if we can't find a solution here.
Photo of Allan
Allan, Mobile Master
  • 62,724 Points 50k badge 2x thumb
Not sure if this will work as it still utilizes the old self serve but you can try it.
Login to self serve, click View Rate Plan, scroll to the bottom and beside Five Essentials click View, click Add Five Essentials, then you're given the list of add-ons as shown above and can add either the International Combo $40 or International Text $15.
Again, if that doesn't work you can send Koodo a message via facebook and I'm sure they can add it for you.
Photo of Kristen
Kristen
That worked!! Thanks! Seems like a pretty convoluted way to get to it though...I hope they find a better way to access the "long list" of add-ons through the newer website.
Anyway, I'm all set- thanks again.
Photo of Allan
It is a bit as it's part of the old self serve. I will flag it with them and see if there is anything that can be done or what the reasoning is behind it!
Photo of Allan
Make sure you have the $0 Pay-Per-Use Intl Long Distance add-on as well.
