how to print textos
  • Updated 2 years ago
Photo of Pascal Trudel
Pascal Trudel
Posted 2 years ago
  • 203,644 Points 100k badge 2x thumb
So I see you're using android.
Depending on the app you're using the answer may be as simple as pressing print or emailing the conversation to yourself for later printing.
I use Chomp which allows me to email the conversation to myself , I can then open the attachment and print it out.
You can use chomp too by grabbing it from the Google play store.
Photo of Mayumi
Mayumi, Mobile Master
  • 111,018 Points 100k badge 2x thumb
Also, you can check "Print Hammermill" from the google play store. I used this app for short conversation, but it was easy and worked well for me :)
Photo of Chadwick
Chadwick, Mobile Master
  • 33,012 Points 20k badge 2x thumb
I also can vouch for the above app^^ have used it before. You can print over wifi/cloud/Bluetooth or a USB cable. Which can make things a lot easier.
