How to keep same number on a new upgraded phone
  • Updated 10 months ago
I bought a new prepaid phone how do I activate it and keep the same number on my old phone ??
Photo of Tracey
Tracey
  • 400 Points 250 badge 2x thumb
Posted 10 months ago
Photo of Sophia
Sophia, Mobile Master
Very simple, Tracey, just insert the SIM card of your old phone into the new one. If it's a different size SIM, you may need to buy one and activate it in self service.
Your account, number and all other information will be exactly the same :)
Photo of Tracey
Tracey
New phone came with sim card old one doesn't fit but how do I keep my same number ?
Photo of Tracey
Tracey
So all I have to do is go into phone services activate new sim card and my minutes and phone number stays ???
Photo of BobTheElectrician
BobTheElectrician
  • 62,064 Points 50k badge 2x thumb
Log in to pre-paid self-serve. Click on the Phone services tab. This will open a new page;  select the Change SIM Card tab. On the next screen, enter the number of the new SIM card that you will use in the new phone and the deed is done.
You may have to reboot the new phone for the change to take effect.
Photo of Tracey
Tracey
Thanks so much appreciate the help
