how to fix the touch pad on a Samsung Corby pro
when I press numbers on the touch pad display a different number shows. I seems like the display has dropped in relation to the actual numbers. I can use the keypad and the numbers correctly appear.
Photo of G Dickie
G Dickie
Posted 3 years ago
Photo of Mathieu
Mathieu, Mobile Master
Hi G,
Have you tried turning off your phone and removing it's battery yet? If not, give that a try and see if that solves the issue or not.
Is with the touch screen only when you dial numbers or anything with the phone?
