How to charge for a boost
  • Updated 3 months ago
Good morning, I bought a prepaid SIM card and I activated it with a base plan.
I tried to buy an extra plan with some GIGABYTE of Data Usage to use internet but when I try my credit or debit cards the website tell me that I can use only a Canadian credit or debit card. I'm in Canada for tourism for some week so I don't have a Canadian credit card. How can I solve this problem? I should activate a data plan on my rechargeable SIM card.. Thanks
Omar di Felice
Photo of Omar Di Felice
Omar Di Felice
  • 80 Points 75 badge 2x thumb
Posted 3 months ago
Photo of Allan
Allan, Mobile Master
  • 56,526 Points 50k badge 2x thumb
You can purchase a Koodo prepaid top up card and load that into your account.
Omar Di Felice
Thank you very much! Do you think I will find in a Walmart where I bought the sim card? Thanks
Photo of Mayumi
Mayumi, Mobile Master
  • 112,530 Points 100k badge 2x thumb
They should have one. I believe Loblaws has one too.
Also, store locator : https://www.koodomobile.com/find-nearest-store
And from their site:
Prepaid top-up vouchers are available in stores across Canada. Check your nearest Koodo Shop, Esso, Canadian Tire Petroleum, Gateway Newstand, Pioneer Petroleum, and Super Sagamie locations.
