how to add data onto plan
How do add data onto my plan?
Photo of shannon rempel
shannon rempel
Posted 3 years ago
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,938 Points 100k badge 2x thumb
Hi Shannon, If you have a prepaid plan then you just purchase boosters on your account through self serve.
If you have a postpaid plan and your data is blocked at the carrier level you can log into self serve and remove the data block or call and have the data block removed.
If you have a postpaid plan and you went over your data allotment for the month you just keep using data and will be charged extra for it at the rate specified within your specific plan.
If you have data already on your plan buy data I'd dialled non your device just go into he settings an turn on or enable data.
