How to add a gb to my monthly plan
  • 2
  • Updated 12 months ago
Photo of Alessio Giansante
Alessio Giansante
  • 80 Points 75 badge 2x thumb
Posted 12 months ago
  • 2
Photo of Erwin
Erwin
  • 23,546 Points 20k badge 2x thumb
Koodomobile.com/selfserve
Photo of Emma Sant
Emma Sant
  • 166 Points 100 badge 2x thumb
yes.I'm on prepaid
Photo of Emma Sant
Emma Sant
should I remove my first plan and add this new one(prepaid)
Photo of Erwin
Erwin
Are you looking at adding a booster or change the base plan?
Photo of David
David, Mobile Master
  • 89,014 Points 50k badge 2x thumb
If you have a Shock Free Data plan, you can also buy additional data when you run out simply by replying to the text message sent you asking if you want to buy more data.
Photo of Emma Sant
Emma Sant
What is a Shock-Free plan
Photo of Mayumi
Mayumi, Mobile Master
  • 112,704 Points 100k badge 2x thumb
Shock-free plan is for postpaid/monthly plan.  You mentioned you have a prepaid, so you just need to buy a booster for your data.
Photo of Allan
Allan, Mobile Master
  • 56,526 Points 50k badge 2x thumb
If you permanently want more data than you will have to upgrade to a plan with more. Elsewise, you can do what David mentioned above.
Photo of Emma Sant
Emma Sant
Please help me understand my account
Photo of Allan
You want to upgrade your plan? Are you on postpaid or prepaid?
Photo of Emma Sant
Emma Sant
I would like to change my plan, Prepaid
Photo of Emma Sant
Emma Sant
How do I do that?
Photo of Mayumi
If you have a prepaid plan and want to have data, then you have to buy a Data booster.
Log into self serve and buy/add it. You can choose how much data you want, but any unused data will roll over if you renew your base plan.
https://www.koodomobile.com/prepaid-plans?INTCMP=KMNew_NavMenu_Shop_PrepaidPlans
