How much to phone Mexico?
  • Updated 5 months ago
I have booked a trip to Mexico, but need to call the hotel directly to work out some issues we are having. The hotel lists a +011 phone number, and I understand this is a long distance number. How much will it cost me, per minute, to phone them? Is it something reasonable like 0.50c a minute, or is it unreasonable like 10$ per minute? I never know with Koodo.
I have unlimited minutes in Canada, and I know its 1.50$ per minute when phoning the US. Other than that, not sure what else my plan allows.
Thanks!
Photo of Caitlin Sloof
Caitlin Sloof
  • 60 Points
  • concerned
Posted 5 months ago
Photo of Dinh
Dinh, Mobile Master
  • 32,964 Points 20k badge 2x thumb
Hi Caitlin,
Are you calling from Canada or from Mexico? (roaming). If you are calling from Canada: https://www.koodomobile.com/help/long-distance-calling
Mexico was listed as $0.5/minute
You mentioned calling US costed you $1.5/minute. It was the roaming pay-per-use rate. You can check the pay-per-use roaming rate here: https://www.koodomobile.com/payperuse
Mexico would cost 1.5$/minute
If you decide to use your phone in Mexico (roaming) make sure you are prepare for it (add add-on if needed) and your phone is compatible with the roaming partner in Mexico.
Caitlin Sloof
  • 60 Points
Wow thank you so much ! This is marvellously useful ! I am calling Mexico from Canada, so based on this it would be 0.50c per minute.
Again thank you for your time and help!
Photo of Mayumi
Mayumi, Mobile Master
  • 112,838 Points 100k badge 2x thumb
If you add "International Long Distance Saver add-on"  $3/mo, then it will be $0.05/min.
You can add this add-on through self serve, and you can remove it at end of your billing cycle.
Photo of Robert
Robert, Mobile Master
  • 103,784 Points 100k badge 2x thumb
If your call is longer then 6 minutes, then I'd definitely recommend this add-on
