How much is the best koodo prepaid plan with data
  • 2
  • Updated 2 years ago
Photo of Heather Dunseith
Heather Dunseith
Posted 2 years ago
  • 2
Photo of David
David, Mobile Master
  • 93,800 Points 50k badge 2x thumb
Go to Shop > Prepaid plans to learn the options.
Photo of Dennis
Dennis, Mobile Master
  • 196,772 Points 100k badge 2x thumb
it depends how much talk and data you use
Heather Dunseith
I use quite a bit of data
Photo of Ivan
Ivan, Mobile Master
Does it have to be prepaid then? Koodo's prepaid isn't geared toward heavy data use.
Photo of Sophia
Sophia, Mobile Master
  • 143,064 Points 100k badge 2x thumb
The most cost effective data option for prepaid is the $30 addon with 1GB, which means you effectively pay $0.03/MB. If you use more than 300(ish)MB per month, it might be cheaper to look into postpaid plans.
Similar for minutes, ultimately it's you who has to decide. As Dennis said if you can give us an indication of your usage, we might be able to suggest a suitable option for you.
