How much for more data?
Currently have 2gb of data month and i would like to increase that. How much would it cost to say double it?
Photo of Tom Forsythe
Tom Forsythe
Posted 3 years ago
Photo of Robert
Robert, Mobile Master
  • 103,858 Points 100k badge 2x thumb
You can not pay to double your data. You need to see what plans offer you more data and change for the one you'd find the most convenient.
Photo of Dennis
Dennis, Mobile Master
  • 187,758 Points 100k badge 2x thumb
Otherwise you use the pay peruse overage data amount. If your pay per use overage data amount is $10/gb then that's an amazing deal and never change your plan as data rates have soared in recent years. It's horrible how much they charge for data
Photo of Robert
Here's how to check how much your overage is.
Go to Self Serve : Plan & Add-on > Plan and then hover your mouse on your plan like on the picture. You should get more info about it
Photo of BobTheElectrician
BobTheElectrician
  • 62,148 Points 50k badge 2x thumb
Just a question... is that $10/GB pro-rated to match your use on the invoice, or are you whacked $10 as soon as you need a sliver of it... like roaming text where the first one costs you $5, the rest are free up to the next limit or bill cycle?
Photo of Robert
Yep. you pay 10$ even if you used 1Mb over your limit! But you may have different fees then mine! Like 5$/250Mb
Photo of Dennis
So if you go over, go Wild.... but within your alottment
BobTheElectrician
All the more reason to pay attention to rikkster's:
Data and how to make the most of it.
http://community.koodomobile.com/kood...
