How much does it cost to repair the charging port of a Galaxy S3?
  • Updated 1 year ago
If possible, what is the range for the cost of repair?
Photo of Michael
Michael
Posted 3 years ago
Photo of Yannick
Yannick
  • 43,998 Points 20k badge 2x thumb
Hi Michael, if the damages are not covered by the warranty (e.g. physical damage), the cost is up to $175. Since it might be too expensive to repair it, considering it's an old model, it might be worth changing for a newer model, such as the Moto G, the Alcatel Idol 3 or the LG G3: http://koo.do/1GgRxzH. If you wish to repair ir, simply go to a Koodo store and rep will help you out http://koo.do/kdostore. Thank you!
Photo of BobTheElectrician
BobTheElectrician
  • 61,868 Points 50k badge 2x thumb
Check with Kijiji for local suppliers. Quoted flat rate for S3 charging port is around $50 in Sherbrooke, QC.
 http://www.lenomade.ca/pages/reparation_appareils_mobiles
Photo of JeremyESQ
JeremyESQ
  • 2,174 Points 2k badge 2x thumb
Sorry to ressurect an old thread -- I had this same problem with my Galaxy S3 and ended up buying an external battery charger on Amazon. The external charger does not have much of an output but is great for overnight charging.
Photo of jackies
jackies
  • 1,146 Points 1k badge 2x thumb
I had the same problem. I got mine fixed for $40 plus taxes. Sadly, I have had other ptoblems since !
