How much does it cost to call HK from Canada?
  • Updated 7 months ago
Hello, I am on the $55/month unlimited minutes, 1GB+2GB Bonus Shock-Free Data plan. I use my own phone bought from Apple. Could anybody please let me know how much will it cost to call Hong Kong for 5-10 minutes using my phone? Will there be an initial minimum charge for making long distance call?
Photo of newkoodouser
newkoodouser
  • 1,020 Points 1k badge 2x thumb
Posted 7 months ago
Photo of Goran
Goran, Mobile Master
  • 97,054 Points 50k badge 2x thumb
There is no minimum. It's just by the minute.
https://www.koodomobile.com/help/long...
There you can select any country, including Hong Kong, and get the per minute rate without and with the long distance saver add-on.
newkoodouser
Thank you Goran. Am I correct that if I make more than 6 minutes call, I better add the International Long Distance Saver before making the call and then cancel it before then end of a one-month period? Does the counting start from the 1st day of each month or from the day I add the Saver plan?
Photo of Goran
Basically yes. Since it drops to 5 cents a minute, you start saving money at 7 minutes I. It counts right when you add it.
newkoodouser
Thanks
