How much data can I add to my plan and how much would it be? I only need extra data for a month
Photo of Marie
Marie
  • 132 Points 100 badge 2x thumb
Photo of Dennis
Dennis, Mobile Master
  • 187,544 Points 100k badge 2x thumb
You have to use your overage rate or change plans to get more data.
Photo of Daniel Gunn
Daniel Gunn
  • 19,800 Points 10k badge 2x thumb
Dennis is right, what plan do you currently have? if you log into your self serve and look at your plan, you'll be able to see what the data overage rates are. The only 'decent' amount for data overages on current plans is $5/250 MB, mind you that's only on the plans that are $60 or more.
Hope that helps :)
Photo of John Lee
John Lee
If you only need extra data for a month, you can just use your pay per use data or use your overage rates. More information on your rates is on your Self Serve > Plan and Add-on details.
Dude, really?
