How does top up work?
What will be topped up, basic prepaid plan + boosters i chose? I need to plan enough money to cover that every month? Need to understand how much money to chose in top up.
Photo of Sylvie LeBel
Sylvie LeBel
Posted 3 years ago
Photo of Sophia
Sophia, Mobile Master
Hi Sylvie,
When you top up, if you do nothing, the money will be used to renew your base plan until it is depleted. If your funds run out, you need to top up again with at least the amount owing to renew your base plan again.
You can also choose to use your funds to buy a booster, obviously you need to have enough to get the one you want :)
