How do you delete calls from alcatel onetouch flipup phone?
  • Updated 2 years ago
How do you delete calls from a alcatel onetouch that is a flip up and does not have a touch screen? The instructions say go to options but you can't get to options by scrolling. Any suggestions? Thank you in advance for any help at all.
Photo of Tom Bosvik
Tom Bosvik
Posted 2 years ago
Photo of David
David, Mobile Master
  • 88,962 Points 50k badge 2x thumb
Have you seen section 6 of this manual? It should get you where you want to go.
Photo of Tom Bosvik
Tom Bosvik
Yes I have gone through the manual but there does not seem to be a way to get to options to get the job done.
Photo of David
  • 88,942 Points 50k badge 2x thumb
Have you tried selecting the specific phone number you want to action (OK button), then choose delete from the choices presented to you? You have to delete them one at a time.
 (It has been a LONG time since I last used a flip phone)
Photo of Tom Bosvik
Tom Bosvik
Thanks for the advice but there is no ok button and no choices presents itself. I think I will just bring it back to the store the next time I am in town.
Photo of rikkster
rikkster, Mobile Master
  • 66,936 Points 50k badge 2x thumb
Pressing the upper portion of the centre navigation pad doubles as an OK button.
Photo of Tom Bosvik
Tom Bosvik
Thank you, thank you and thank you. Problem solved.
Photo of rikkster
You're welcome, Tom!
