How do I set my PIN?
  • Updated 5 months ago
I never created a pin when I set up my self serve account, how do I go about setting one up?
Photo of Amanda Gz
Amanda Gz
  • 162 Points 100 badge 2x thumb
Posted 5 months ago
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,574 Points 100k badge 2x thumb
Do you mean the pin you would have set up when you first signed up? You would have told the salesperson a 4 digit pin when your signed up with koodo they ask you what you would like your pin to be
Photo of Amanda Gz
Amanda Gz
I set up my account online
Photo of Amanda Gz
Amanda Gz
It never asked me to set up a pin
Photo of Dinh
Dinh, Mobile Master
  • 41,844 Points 20k badge 2x thumb
I think you could try either 1234 or your last 4 numbers of your phone number. It might work. You also should change your PIN in your selfserve if it wasn't set by you. I beliieve it was in "my profile" of selfserve
Photo of Amanda Gz
Amanda Gz
I tried to reset it in the self serve but it requires your old pin which I don’t have :(
Photo of Dinh
Dinh, Mobile Master
  • 36,794 Points 20k badge 2x thumb
I would try 1234 and last 4 digit of your phone number as your "old PIN".
If it doesn't work, you would need to contact Koodo to ask them to reset it for you.
