how do i reset my service ,having trouble with lte service on phone and did troubleshooting with samsung and they said to reset service
  • Updated 2 years ago
how do i reset my service ,having trouble with lte service on phone and did troubleshooting with samsung canada and they said to reset service "samsung note5"
Photo of Garth
Garth
  • 172 Points 100 badge 2x thumb
Posted 2 years ago
Turn your device off and turn it on again. Or cycle airplane mode. Or turn it off and remove the sim then replace the sim and turn it back on.
Photo of Garth
Garth
still not connecting to lte
Photo of Goran
Goran, Mobile Master
  • 90,488 Points 50k badge 2x thumb
Try going to settings, backup and reset, reset network settings. Make sure LTE is enabled as an option to connect to first actually by going into mobile networks, network mode and make sure the option selected includes LTE.
Photo of Garth
Garth
just 3g no lte
Photo of Goran
Which options exactly do you see? Did you try the reset?
Photo of Garth
Garth
wcdma/gsm thats it ,when i did the 6.0.1 marshmellow update LTE stopped working ,ive done factory resets cache resets , contacted samsung and they said to have network provider reset service
Photo of Garth
Garth
sorry i did try the network settings reset
Photo of Garth
Garth
no luck
Photo of Garth
Garth
can not send text messages
Photo of rikkster
rikkster, Mobile Master
  • 67,080 Points 50k badge 2x thumb
Try dialing *#2263# from the phones' dialpad. Select [1] Band Selection. You're looking for the combination of LTE/WCDMA GSM Auto. If you see this combination, tap to select it and then tap again to confirm the selection. To exit, tap MORE > END. Do not reboot your phone.
Photo of Garth
Garth
tried that still stays on 3g
Photo of rikkster
Can you show me a screenshot of the ServiceMode/Band Selection page (*#2263#), please? I'd like to see the list of network types available on your Note 5. Thanks.
