how do i reset a sim catd pin?
  • Updated 2 years ago
Photo of Christopher Krezanoski
Posted 2 years ago
Photo of Mathieu
Mathieu, Mobile Master
Hi Christopher,
What type of phone are you using? Do you need to change it because you can't remember the PIN you have already put in, stopping you from powering on the phone?
Photo of Chadwick
Chadwick, Mobile Master
  • 33,072 Points 20k badge 2x thumb
If your referring to the PUK code, you will have to call customer care to get it as they are the only ones who have it.
