How do i know if my KOODO phone is locked and if it is , how do i unlock it?
  • Updated 10 months ago
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: Unlocks are now free
I have an HTC from Koodo.  I am going to be traveling in New Zealand so need it to be unlocked.  How do i know if it is locked?  How do I unlock it?
Photo of Judy Falussy
Judy Falussy
Posted 10 months ago
Photo of Robert
Robert, Mobile Master
  • 106,876 Points 100k badge 2x thumb
You need to insert another SIM card in it to see if it's unlocked. If it works then you're good. If not you need to buy an unlock code on eBay or call Koodo
Photo of Goran
Goran, Mobile Master
  • 97,204 Points 50k badge 2x thumb
Since you mentioned an android it'll be cheaper to get it from eBay. Also you said you got it from Koodo so unless you unlocked it yourself it'll probably be locked but otherwise as Robert said.
Photo of titaniumtux
titaniumtux
  • 12,952 Points 10k badge 2x thumb
I got the unlock code for a Koodo-locked HTC for a twoonie on eBay. Definitely the cheapest option.
If you're travelling to New Zealand before December 1st, buy the unlock code on eBay. If you're travelling after December 1st, get the code free from Koodo on December 1st.
Bon voyage!
Judy Falussy
Thanks for the info.  One follow-up question:  on Ebay the unlock codes range from $2 to $20.    Any reason not to go for the least expensive one if the seller has positive reviews?
Photo of David
David, Mobile Master
  • 93,318 Points 50k badge 2x thumb
None at all. Put $18 in your pocket.
Photo of Yuan Zuo
Yuan Zuo
  • 112 Points 100 badge 2x thumb
Heads up, I called to unlock my iPhone cause I'm buying the new one and wants to sell my old one and had to pay $50 to unlock it.
Photo of Goran
  • 96,848 Points 50k badge 2x thumb
Yes and that's the cheapest for iPhone. Once December 1 comes though it will not cost anything.
Photo of Yuan Zuo
Yuan Zuo
Thanks for letting me know!
