how do i get rid of my incoming or outgoing calls?
Photo of Rose O'Donnell
Rose O'Donnell
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 202,996 Points 100k badge 2x thumb
If you mean from your call logs then tap on your dialer and then go to your call logs.
Then tap the menu button and select to delete call history.
The menu button may be on the phone or 3 dots in the corner of the screen.
