How do I get home phone number when changing to Koodo home phone?
  • Updated 1 month ago
Photo of Tracey T.
Tracey T.
  • 104 Points 100 badge 2x thumb
Posted 1 month ago
Photo of Dennis
Dennis, Mobile Master
  • 182,206 Points 100k badge 2x thumb
When you activate you have the option to choose a new number or port a number in
Photo of Tracey T.
Tracey T.
Thanks Dennis. Are there clear instructions to do so? If I have a problem can I call or will they charge me to help?
Photo of Robert
Robert, Mobile Master
  • 102,372 Points 100k badge 2x thumb
They won't charge you but I'm sure the instructions are quite clear.
Photo of Tracey T.
Tracey T.
So I'm going to order tomorrow. Do I need to be in touch with Bell or what happens? Will we be without phone services in between? I'm so confused but want to do it correctly.
Photo of Goran
Goran, Mobile Master
  • 83,168 Points 50k badge 2x thumb
Do not get in touch with Bell. Koodo will handle the number port. You will get a final bill from bell and you just pay that and you're good.
Photo of BobTheElectrician
BobTheElectrician
  • 59,858 Points 50k badge 2x thumb
I would suggest: Get the Koodo set-up with a temporary number. You can then test suitability, signal strength etc without compromising your current number during the free-return period.
ONLY If things are good should you then port in the number.
If you have to return the home phone base for any valid reason, it's much less complicated to cancel a temporary number and leave you original service untouched than to re-instate your cancelled account with that same number.
